Exactly. Only for export. It is nice cause now I can export my list and then use XSL to transform/display it in any format that I want..Maybe I will write an XSL to do a simple list and post it here...EDIT: Although import may be possible...for instance if you wanted to resturcture the playlists....maybe it would have to wipe out what was there and build it based on your XML...You could not create new playlists but maybe move/copy tunes/playlists to be under other playlists. That would be a function of Emplode to read it in and redo the structure.
Edited by Squid2k1 (28/12/2001 13:56)
Squid2k1
18GB of revived Green Mk II Fury - Fast As A Shark
