For what it's worth, I'd like to see the processing moved client side as well. Whether it's HTML with CSS or XML with XSLT, client side will be a heck of a lot more flexible in the long run.
Even if some basic server side template ability shows up, we should definitely still have the ability to have Hijack serve an XML stream with an tag declaring the appropriate XSLT sheet. Barring that, it should have a way to specify a CSS in the HTML output. The appropriate XSLT/CSS can be hosted on the empeg so that the client can fetch it when referenced and do it's processing.
-Aaron
-Aaron
