I wonder if I'm holding onto memory somewhere ...Never seen that before. About how many songs tunes are you dragging-and-dropping?
jEmplode is ported off of emptool which does have more strict considerations for errors (things like 0 reference count = error in emptool, but = soup-only song in emplode) -- It's possible that since missing references can be automatically fixed that Emplode doesn't actually consider it an error (emptool does though). You're seeing the new error message (the old one would have incorrectly told you to look in Unattached Items). Same error, different message. After you did a sync, did the problem go away? Usually if I get those (which are exactly what you said -- dropping connection during a sync causes those), then one sync (with Emplode _or_ jemplode) will fix it all up. Let me know.
I'll look into the memory thing.
Mike
