Apparently there is a memory leak in Dan's MP3 parser
I have gotten out of mem errors importing mp3s with id3v2 image tags before. I am not sure if it was with DMZ's taglib or the older id3lib based one though. I bet if Tony uses something to strip out any less common tags it will work with the newer parser. I eventually wrote a perl script to strip and clean my tags on all my mp3s which is the main reason I never have bug reports for you any more :-)
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
