#106676 - 22/07/2002 20:56 sync errors...help
lastdan
Loc: santa cruz,ca
mk2a, 2.11b about 10gig loaded, new, newbie
ok..
things were going just fine up till i put it in the car.....
found out how important playlists are so back to the desktop to emplode some.
a) reading the player configuration seems to take forever (nearly 3 minutes), then things seem normal...until....
b) when i try to sync the player I get an error right after it completes writting the player configuration (another 4 minute wait, 0x80072746 )
if I try to sinc again it halts right away and tell me "someone was here before us" (or error 0x80040017 )
if i close emplode and restart it the whole thnig repeats.
please note that what ever changes I have made in the first emplode 'stuck'....so in a way it works.
no modes or jacks yet
a search for the error codes came up dry.
ethernet....same set up, worked fine last week ???
added: winXP
Edited by lastdan (22/07/2002 21:10)
#106677 - 22/07/2002 21:00 Re: sync errors...help [Re: lastdan]
mrfixit
If you don't have hijack on your player, put it on there and then try it.
Ben
hijacked
#106678 - 22/07/2002 21:21 Re: sync errors...help *DELETED* *DELETED* [Re: mrfixit]
lastdan
Loc: santa cruz,ca
Post deleted by lastdan
#106679 - 22/07/2002 21:31 Re: sync errors...help [Re: lastdan]
mrfixit
Umm.. why are there 5 of the same replies? is the long read/write confuration normail? It should not take that long.
Ben
hijacked
#106680 - 22/07/2002 22:23 Re: sync errors...help [Re: mrfixit]
lastdan
Loc: santa cruz,ca
BOOB WARNING !!! I'm a moron!
sorry for the mis-spelled posts-a-many.
the read / write time for my configuration is no less than 4 minutes (20gig with about 9 gig free). it works through it when reading, but the sync halts after it writes at the 'restarting player' line.
again, I'm not drunk, just stupid.
#106681 - 22/07/2002 22:29 Re: sync errors...help [Re: lastdan]
Your configuration problems are most likely due to a known bug in beta 11. Please click here for the solution.
#106682 - 23/07/2002 00:39 Re: sync errors...help [Re: tfabris]
lastdan
Loc: santa cruz,ca
yup , you nailed it.
a bizillion lines in my config.ini that I didn't need.
thanks.
no more long sync times, no more errors.
