#214918 - 29/04/2004 02:16 HD 80GB Toshiba upgrade issues, ext2 not found??
ratscrew
I am having problems getting my new 80 gig Toshiba drive to install correctly. (model mk8025gas). I am simply trying to replace my factory 20 gig drive with this new drive.
Applying the upgrade seems to work (pumping partions/ complete) and I immediately open up hyperterminal per the directions.
The drive is recognized (as hda correctly) but further on down the text, it says no primary drive.
The directions say it should start formatting the disk, but I have not seen this happen yet.
Here is the print out of the info on my hyper terminal.................................................................................
(it'
No primary har
or forever hold their peace...it seems not. Let fly the Penguins of Linux!seco
bash: e2fsck: command not foundempeg init 0.8
e000 v1.04
Copying kernel...eg:/dev# rw
Calling linux kernel...No secondary ha
Restart code received
l.
e
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315
empeg:/dev# rwm
mount: /drive0 not mounted
(release)) #11 Tue Apr 1 18:49:59 BST 2003
Processor: Intel StrongARM-1100 revision 11gs.cpp
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel C
˙If there is
empeg:/drive0# ls0x4054d
Page cache hash table entries: 4096 (order 2, 16k)/drive0# ls -a
en
. .. f
POSIX conformance testing by UNIFIXgss
Linux NET4.0 for Linux 2.2
Parallelizi
No
empeg:/drive0#
NET4: Linux TCP/IP 1.0 for NET4.0rive0# cd .. read-onlyp1
empeg:/bin# hdstres: 61:
empeg dsp initialised
empeg:/bin# hdstress
N
Nn
Nn
Ni
Prolux 4 empeg
empeg usb initialised, PDIUSBD12 id 1012ed checking /dev/hda3
empeg state support initialised 0089/88c1 (save to d0005800).
Ni
Nt
Nl
Ne
empeg RDS driver initialised
Read/write of 8Mb too
Remounting
hdstress.cpp 189 ( 6
empeg single channel IDEa: Spinn
hdstress.cpp 189 (
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...okay
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarti
ng player
! tags.cpp : 61:Failed to open tags (0xc0041002).
Vcb: 0x4054d000
I am not using any jumpers on the drive since it is the only drive. I am concerned over this line...
as it seems like the one that starts my problems....
can anyone assist me on this issue?
( i have tried deleting all partitions created to start the update fresh, and sure enough all partitions 1-6 are created on the drive, but i still get the no primary drive error...)
Chris
#214919 - 29/04/2004 02:56 Re: HD 80GB Toshiba upgrade issues, ext2 not found?? [Re: ratscrew]
Was this log taken with Hyperterminal? If so, can you do that again, but this time, use the Transfer/Capture menu option to save the log to a file: Choose a file, and then turn on the player.
Hyperterminal's scroll back buffer is about as sane as a ferret with advanced dementia.
#214920 - 29/04/2004 03:16 Re: HD 80GB Toshiba upgrade issues, ext2 not found?? [Re: Roger]
ratscrew
here is the more readable version (though this is not the first boot after the update... i will try that and post that again now)
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 7, serial number 90000805)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg state support initialised 0089/88c1 (save to d0005d00).
Probing primary interface...
hda: TOSHIBA MK8025GAS, ATA DISK drive
hda: TOSHIBA MK8025GAS, 76319MB w/0kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:25
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
Press Ctrl-A to enter pump... VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Vcb: 0x4054d000
#214921 - 29/04/2004 03:25 Re: HD 80GB Toshiba upgrade issues, ext2 not found?? [Re: ratscrew]
OK, so your music partition isn't formatted. How did you format the new drive? You used the builder image, yes?
Either try that again, or follow these instructions to format it manually. You'll have to replace every instance of "hdc" with "hda" if you've got the disk installed as the first drive in your empeg.
#214922 - 29/04/2004 04:52 Re: HD 80GB Toshiba upgrade issues, ext2 not found?? [Re: Roger]
Greetings!
It would be a good idea to try and capture a log of the build as it is going. There is a known weirdness with the builder (does anyone know if it is a proven bug) where you sometimes have to run it more than once.
#214923 - 29/04/2004 11:52 Re: HD 80GB Toshiba upgrade issues, ext2 not found?? [Re: Roger]
ratscrew
Thanks so much Roger! Seems like there was an issue with the .upgrade file writing to my drive. Now all is well and i have 74 gb free in emplode!! Thanks so much!
Chris
