#223259 - 16/06/2003 00:40 RIO Usage tip
dionysus
Loc: San Francisco, CA
OK - so after struggling w/ jreceiver/trio/rioplay/reza's rrr; and not having much luck actually navigating the music w/ any of them (comeon; I've got 10000 mp3's.. ever try sorting through that many??), here's my usage -
I'm running rioplay talking to jreceiver (although I'm not really using jreceiver.. ) here's how I *am* using it -
I'm also running streamsicle http://streamsicle.com/index.shtml
rioplay has two main stream configured in /etc/streams.cfg - the streamsicle url, and a second streamsicle url which is actually same url, with streamsicle's built-in sleep timer...
(SO -
<title>MVStream
http://powerhouse:4711
<title>MVStream (sleep 60)
http://powerhouse:4711/timer/60
Streamsicle has a very cool web interface which lets you 'request' songs or cd's, but plays randomly if you choose not to. It's very good about keeping the order of a cd and playing tracks in order if you choose to request an entire cd; and has features such as a quick search, and finding id3 tag info on current song/finding directory that the song came from and requesting more songs from it/etc..
..and if I want rio to go to sleep; I choose the second stream...
Check it out guys; definately worth looking at...
-mark
http://mvgals.net
#223260 - 18/06/2003 14:42 Re: RIO Usage tip [Re: dionysus]
damage
Does anyone know if streamsicle can be used with trio (like a shoutcast channel maybe?)? It looks pretty cool...
#223261 - 18/06/2003 18:07 Re: RIO Usage tip [Re: damage]
Given that they are recommending WinAmp as the best client I'm guess that the output is a Shoutcast stream. Just a guess though.
#223262 - 19/06/2003 17:31 Re: RIO Usage tip [Re: andy]
dionysus
yeah; it's just standard shoutcast stream..
I'm having problems with higher bitrate files though; lots of clipping w/ the rioplay client (works fine w/ winamp..) works perfect for ~256kbit and below though..
-mark
#223263 - 19/06/2003 21:12 Re: RIO Usage tip [Re: dionysus]
dionysus
update - no clipping w/ rioplay .28; but it clips w/ .29alpha2 (what changed?)
-mark
#223264 - 19/06/2003 21:39 Re: RIO Usage tip [Re: dionysus]
damage
did you need to create a .pls file to make it work w/ rioplay? can you post that .pls file? i can't seem to get it to work.
#223265 - 09/07/2003 17:16 Re: RIO Usage tip [Re: dionysus]
DonRon64
Loc: NC
Hi All,
I'm new to this board so go easy on me. ;-)
I'm trying to use Streamsicle in a simular way as you. (RioPlay, ARM) [BTW, I think Streamsicle is very cool.]
I've been looking this board over and think my question may have been answered in another context, but thought I would ask again...
Is there any way to edit the 'streams.cfg' in RioPlay and replace the one supplied in the distribution TAR without having to build a linux box?
I've tried using WinRar w/o any luck.
#223266 - 10/07/2003 04:59 Re: RIO Usage tip [Re: DonRon64]
happy_hammer66
newbie
I cant remember exactly but its something like this:
get a dos program TAR.exe
tar -tvf #list the files
tar -xvf streams.cfg #extract streams.cfg from .arf file
tar -dvf streams.cfg #to delete streams.cfg from arf file
modify streams.cfg as needed
tar -rvf streams.cfg #might need to specify full path
#223267 - 10/07/2003 19:00 Re: RIO Usage tip [Re: DonRon64]
dionysus
if you can't figure it out, send me the url that you want in streams.cfg and i'll be happy to build it for you.
-m
http://mvgals.net
#223268 - 27/07/2003 15:35 Re: RIO Usage tip [Re: dionysus]
Tone
newbie
First Post! Please don't be too cruel.
Have set up tRio (using ARM). Works fine.
Am now trying to link to Streamsicle & have set up pseudo radio station as follows in trio.xml
<station name="Streamsicle" url="http://playroom:4711"/>
Doesn't work, the shoutcast radio stations work OK though.
Has anyone done this? Any ideas what I've faoiled to do?
All advice appreciated
Tone
