#51344 - 24/12/2001 18:40 Clock visuals truncated
beaker
Loc: England
Haven't seen anyone else post this so thought I'd better. The clock visuals are truncated at each end. Anyone else notice this?
#51345 - 24/12/2001 18:45 Re: Clock visuals truncated [Re: beaker]
Mine aren't. Then again, I'm set to a 12-hour clock and haven't looked at it when the numbers are at their widest....
#51346 - 24/12/2001 19:25 Re: Clock visuals truncated [Re: tfabris]
beaker
Loc: England
Yeah, mine's ok now It's past midnight. Can you try it out in 24hr mode and see if you get the same symptoms.
#51347 - 24/12/2001 20:55 Re: Clock visuals truncated [Re: beaker]
I noticed truncated clock in 2.0b3 but never remembered to complain about it here. Tends to happen when the hour is 2 digit (10 and above.) Only in certain clock modes, like it probably doesn't happen in Clock Zoom.
I think we should have a Clock: Snow visual too.
#51348 - 24/12/2001 21:48 Re: Clock visuals truncated [Re: tfabris]
In 12 hour mode it should be OK. The digits should touch each edge of the screen when using all four digits. The first digit (of 4) can only be a 1 in this mode.
There is definitely not enough width available to show 4 wider digits (such as 20:20 or 22:55) - not unless the digits are scaled down.
#51349 - 24/12/2001 22:31 Re: Clock visuals truncated [Re: hybrid8]
I've definitely seen at least one clock info mode that had problems even though it was a "1" in the first position. Like maybe 15:30 or something like that.
#51350 - 25/12/2001 04:19 Re: Clock visuals truncated [Re: tonyc]
beaker
Loc: England
It happens in Clock Zoom too.
#51351 - 10/01/2002 12:38 Re: Clock visuals truncated [Re: beaker]
beaker
Loc: England
So has this been put in the bugs list?
#51352 - 10/01/2002 12:59 Re: Clock visuals truncated [Re: beaker]
#51353 - 10/01/2002 13:20 Re: Clock visuals truncated [Re: Roger]
beaker
Loc: England
OK, thanks. Just thought I'd ask .
#51354 - 10/01/2002 13:23 Re: Clock visuals truncated [Re: Roger]
Just give us access to the internal bug list, damn it!
(I know... Standard dry British humor response: "But then it wouldn't be internal!")
