My config.ini file was wack, but after fixing it (and I confirmed twice that it was fine), the player is STILL not remembering to apply the Wendy Filter after a power cycle. Here is how it is working:
1. Say I suffle the root. The player will be playing on track 10 of 9266.
2. I apply the "Music Only" filter, and after a short pause, the player continues with the same song, but this time at track 10 of 8931. (This is normal).
3. While the track is 1/2 way through, I power down the player.
4. Upon booting, the player is now 1/2 through on track 10 of 9266! But track 10 is a different song!
5. Before my config.ini fix, it would usually start at 0:00 AND the wrong song (usually a track or two earlier in the playlist than it was supposed to be at).
Also, on AC power, the player is always defaulting to the last non-full screen info mode even if the "Track" mode was manually selected prior to powering down. I think someone else has brought this one up... so it is most likely a known bug.
I always power down the player before killing the ignition. (I even put it in its case before turning off the car... to let the turbo cool
