In reply to:
Do we still need to do this?
5. You may need to replace the empegs init with a script that mounts the drives as ext3 instead of ext2. I already was using a custom script so I didn't worry about this.
Nope, you can skip steps 3,4, and 5. The kernel takes care of all that now. It sounds like you are all set. So you have a dual drive player right? Do you get a stack trace when the player remounts the drives after a sync? I still haven't had time to try and fix that one.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
