You can always press control-c during the boot cycle. That should drop you to shell. Then turn on swap (swapon /swapfile), unmount and check all of your filesystems (umount /drive0; umount /drive1; fsck -fay /; fsck -fay /dev/hda4; fsck -fay /dev/hdc4) and then reboot. You will still get that building databases the first time, but you should be able to go into shell normally then and correct it by hand.
Paul Grzelak
