I get the following, and I think it might be bad news....
empeg:/empeg/bin# ro
mount: /drive0 not mounted already, or bad option
empeg:/empeg/bin# umount /dev/hda4
umount: /dev/hda4: not found
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1514/4096 files (0.5% non-contiguous), 9457/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
fsck.ext2: Filesystem revision too high while trying to open /dev/hda4
The filesystem revision is apparently too high for this version of e2fsck.
(Or the filesystem superblock is corrupt)
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
I don't have backups of a lot of the stuff here so it'd be nice to recover whatever I can, but it's not the end of the world if I lose it.
Steve.
Mk2a 10+40Gb Darkstorm Neon Red Nakamichi CD45z, Genesis Five Channel, Genesis A16s, JL 8W6 x3
