Hi again - thanks for your help on this !
It seems to boot up and run fine if I only use the 10Gb drive, so I've removed that and put it somewhere safe for now. I hope that's not going to cause any problems.
Running from just the 40Gb drive, it *appears* to boot correctly but does not have any playlists available. Looking at the output in Hyperterminal (and bearing in mind I'm not really a computer person) it all seems reasonable apart from this bit:
Mounting proc
EXT2-fs: ide0(3,4): couldn't mount because of unsupported optional features.
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
So it's booting up, but still can't find the drive ?? If worst comes to worst I can just rebuild the drive, but I don't have backups for quite a lot of music on there.
TIA,
Steve.
Mk2a 10+40Gb Darkstorm Neon Red
Nakamichi CD45z, Genesis Five Channel, Genesis A16s, JL 8W6 x3
