OK, I tried doing mcomb's suggestion, but I'm not quite sure what happened. I then did the -s whatsit and got this:
empeg:/empeg/bin# mke2fs -S /dev/hda4
mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
4872896 inodes, 9741414 blocks
487070 blocks (5.00%) reserved for the super user
First data block=0
298 block groups
32768 blocks per group, 32768 fragments per group
16352 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624
Those last two numbers are new, so I tried the fsck command again with the first of the new numbers but get
fsck: fsck.ext2: not found
I think I've screwed something up.
Steve.
