Oops! Music FID ffffffff1 not found!
I might be mistaken, but I think this happens if you don't have "notify=1" in your [output] section of the config.ini. Of course, my install script should do this for you, but it doesn't, because I forgot. That will be fixed in the next release.
Is that the problem? If you do in fact have notify=1 in there, then I'll have to investigate further.
