Since many people here run Firefox, would you mind verifying a bug I'm seeing with all versions since the 1.0.1 release? The problem is that when a page uses javascript to create a new window (like for showing an image), instead the content gets placed in the current window.
Here's a perfect site to test this on:
http://products.gateway.com/products/GConfig/proddetails.asp?system_id=plsm42ubtv&seg=hmJust click on the picture of the TV. It's supposed to pop open a new window with an enlarged image. When you click on the enlarged image it's supposed to close that new window. Well the close part works fine, but you can see what happens when done when experiencing this bug.
I'm seeing this on all Mac OS X builds so I'm really curious if other platforms are also affected. I've tested with a handful of nightly trunk builds of 1.0+ as well the recompiled/optimized G4 version. Going back to 1.0 remedies the problem (without changing any prefs).
Thanks.
