The U.S.English (us) layout on my machine has a Dvorak "Layout variant" already, so you just need an easy way to switch between it and the regular layout.
I may not have been clear -- on SuSE, there is actually a Dvorak layout, which is an additional entry to the US English layout (which has its own dvorak variant). That's what's missing on the KUbuntu install.
The KDE Control Center --> R&A --> Keyboard Layout menu has a drop-down menu for this purpose, or you could just use a one line shell script similar to SWMBO's to do it, without having to navigate all those menus.
I'll go the latter route, if necessary. I'm trying to find a way to be able to do it via point-n-click, since it's really going to be my girlfriend that needs it most of the time.
I'm running KDE 3.5, which is newer than the stock Breezy KDE.
You also could upgrade to KDE-3.5 on Breezy, by adding this line to /etc/apt/sources.list: [...]
Ah, cool. I'll check that that's in my apt sources. I haven't gotten as far as upgrading to all the packages I really want, yet, since I got hung up with the keyboard layout thing. (The install happened overnight last night, and I only had a half-hour or so to play with it this morning before work.)
