I came to the same conclusion...: Empeg would sit better in the wider space up top
There is a problem with that, but it is so trivial I hesitate to mention it. I bring it up only for you to keep in the back of your mind.
When the empeg is in the top slot of a tight double-din installation and both units are flush with the dash, it is difficult to grab hold of the release handle of the empeg to pull it out of the dash. If you have a good fingernail on your right index finger, it is not so bad, but otherwise you will struggle.
Like I said, trivial, and about the only disadvantage I can think of to putting the empeg up top.
