Sure, no problem having the power cable alongside the ethernet.
With a half-inch hole, I don't know if the RJ45 plugs will fit through the hole or not -- might need to just feed a raw cable end through the hole, and have somebody crimp a new connector onto it afterward.
One thought, if you're going to do a ceiling mount: shop around for a small, modern router (no more than USD$20) with keyhole slots for screws on the underside. Makes mounting easier, and probably will look better too. The model I would like to recommend (tp link wr720n v1) is no longer sold, but was small, cheap, and very low on power usage.
Configure the downstairs router as a "router", with a separate SSID on a different channel from the upstairs one...
I hesitate to disagree, but configuring the secondary WiFi unit as a 'router' would create a double NAT configuration, no? Is this intentional, to prevent the computers on the second WiFi from easily 'seeing' the primary local network?
Personally I prefer to utilize the 'guest network' facility in a modern router to create two WiFi networks with separate SSID but central control and monitoring of everything from the primary router. In my current case these happen to be Apple gear, AirPort Extreme and Airport Express. Certainly
easy to manage , and for me they have tended to be very stable over time. Pretty good signal quality and range, the stability and consistency has been the attractive aspect.
I long ago tired of the bleeding edge WiFi gear that needs multiple updates before it becomes trustworthy, if it ever gets there. And the really cheap stuff is all over the map, can consume a lot time and energy sifting through all the crap looking for something that won't become trouble later on.
