One small difficulty will be securing the router to the ceiling...
Uh-oh! I have to get power to the router as well. Can I run the power cord right along the Ethernet cable without causing interference?
Some routers have keyhole style mounting holes on the underside, which can hold the unit to the ceiling of the holes are carefully located and the screws are just the right size to provide a snug fit, and screwed in until they just barely allow the slots to fit over the screws and slide into position.
If you choose this method, I can provide a
tip for getting the drilled hole locations fairly precise without any measuring. There are purpose made ceiling mounts,
this one fits the compact
Apple Airport Express router.
[video:youtube]
http://youtu.be/cWLjo9yPFKc[/video]
