4- run the ethernet cable from a LAN port of the primary router to a LAN port of the secondary router.
Speaking from my usual position of invincible ignorance... wouldn't it be logical to run the Ethernet cable from the LAN port of the primary route to the "Internet" port of the secondary? Wouldn't the secondary router then be just as happy with the incoming signal as it would be if the signal were coming from its own cable modem?
No worries. It does seem illogical. This page has some explanation a little ways down.
Tomato and DD-WRT also have ways to turn the WAN port into an additional LAN port, but that's not really necessary.
Not to beat a dead horse, but let me put in one more endorsement for Unifi, with a pro/con list
Pro:
- seamless roaming between access points, which could be important now that you're going to have an AP in the lower floor that really could deliver signal to the first
- POE means you don't have to run power through that hole
- a real, included mounting bracket will make the result look great, like just another smoke detector (you'll see no wires)
- you don't have to worry about all this configuration confusion (don't have to deal with DHCP or flashing firmware, and there's only one place to plug any of the cables into
Cons:
- more expensive, requiring two APs and a router (you'd disable the wifi in the router). The base Unifi AP costs about $70. The longer range version, which might not be necessary in your configuration, is about $83. Lastly, they have a brand new 802.11ac dual band version that's about 40% of the previous cost at $99.
- the management software can be a little annoying at times, but they've really improved it in recent months with a big visual refresh
In the end, I totally understand going the less expensive route, though.
