"restore visuals" now works with beta7
I'm using 2.0b7 (Consumer), with hijack 87, and I can't seem to get this to work. Every time my player boots up in the car, it starts off in "Now & Next" mode.
I do have some other wierdness that might be related... "Volume ramps up gradually" only works on my player the first time after I physically pull it out of the sleeve, and then put it back in. In other words, when I start my car with the player already in there, it comes on with the volume wherever I left it at, with no ramp. But, if I've just put the player in the sleeve, then the ramp works fine.
As far as I can tell, the player does think it's in car mode, because the dimmer menu item is there, and it functions as expected when I turn on my headlights.
One other thing I noticed though, is that I always have an option to "Force DC/Car Mode". Shouldn't this change to "Force AC/Home Mode" if I'm in the car? It doesn't...
So, I'm guessing that somewhere the notion of "Car Mode" is being lost.
Any ideas?
Let me know if you need more info, or have any tests you want me to run.
DarioMK2 in an Impreza 2.5RS
