Hey mo3211,
I did eventually get the Empeg Clone to work properly. You have to go back and use the original Version 1.03 Emplode and Player software, works flawless. Only problem is, as far as I remember, it sync's over the serial connection which is REAL slow.
For some reason, all of the 2.xxx versions I tried to clone with would only find one player and I never was able to make it work in JEmplode either. Actually, I'm using WsFTP now to do all my sync's. This is nice 'cause it can be done quickly over the ethernet connection and provides a backup if anything were to happen to your Empeg hard drives. Just need to install Hijack to enable FTP on your Empeg.
Bodybag - So Cal
Not a Whiner any more!!!
