question.. i'm going to start using a preinit script to run rsync on startup, so i need to know if its safe to run it while the player app is still up? and if it eventually gives up if it doesnt find a network connection (i.e. in the car).
is there any sure way to know that i even have a network connection? somewhere in /proc maybe? so i can make the script conditional.
also, even though the database and playlist is functional, everytime i run emplode after rsync is done, it has to add/change something (litte red cross). i was thinking of doing a file compare, so you can implement what happens to the database/playlist generation code. or you can do it yourself.
