Thanks for the update on the CR-V. Good to know you can squeeze a double-DIN in there.
except the Pioneer I have on top looks like sheat as the trim ring will not fit in with the empeg in place.
If you look at Dionysus' pictures, he has a trim plate in front of his CD player (not the CD player's trim ring). I don't remember if this was a mounting kit or if he cut his own plastic piece for it. I cut my own.
If you want to cut your own plastic piece to make it look better, here is what I did:
Go to the stationery store and get:
1) Metal ruler
2) Very sharp x-acto knife
3) A cheap black 3-ring binder with a flexible plastic cover.
Use items 1 and 2 to measure and cut number 3 into a piece that perfectly covers everything.
If you post pics, put them in the "Installation Notes" section, not this thread.
___________
