Perhaps that piece (or one like it from another vehicle) could be modified to slide into the empeg bay?
The plastic compartment I pulled out of my VW Passat looks like it would fit quite nicely in the empeg sled with a bit of trimming. The interior dimensions look like they would fit in the sled while there is a lip that extends slightly outward that would probably cover up the exposed metel and give it a clean look. It's also not as deep as the DIN slot so I think it would clear the docking connector without having to cut a hole in the back.
If anyone is interested there might be a part number I can pull off it.
-Dylan
