No problem, glad that I could help.
I know we've discussed this but I'll throw it out here to see if anyone else is interested. I'd like the standard button colors with the smoke buttons to match the original but I'd like to have buttons with a phosphorescent tint (blue and blue green would work best but other colors are available) if its a viable option.
Also depending on what the caster says, a frosted effect may be a decent option also (via sand blasting after casting).
I'd also like to bring up the flexible button option here.
Finally, metal like finishes may be possible with something like this but the caster would have to decide if it's possible and worth the trouble. It's doubtful they would be illuminated if the powder was dense enough to give a metallic finish but it could, if it was only metal flaked. ( Hmm, frosted, glows in the dark, flexible with metal flake....if you can get a treble hook embedded in them I'll use them for fishing )
If any of these options are plausible, I would pay extra for them.
Thanks!
