#202228 - 03/02/200418:02Re: jEmplode + Pearl + Jupiter + Empeg = One Wild
[Re: MysticalBS]
tfabris carpal tunnel
There is no keyboard but you can add one via the USB port right?
Correct.
How do you enter this into the central?
You don't. That's a the DOS command line on a PC with the latest Sun Java Runtime engine. Note that this requires ethernet, which is not built-in to the Central (it requires one of the few compatible USB-to-Ethernet adapters for that).
