If anyone wants to give this method a shot, you should know the following commands:
mkdir /mnt/hdb
mount -t ext2 /dev/hdb /mnt/hdb
cp -r /drive0 /mnt/hdb
Using the serial debug dongle (I couldn't get to a shell from the USB keyboard with two hard disks installed), I tried these commands. Here is what I got:
jupiter:/# mkdir /mnt/hdb
mkdir: cannot create directory `/mnt/hdb': Read-only file system
jupiter:/# rw
jupiter:/# mount -t ext2 /dev/hdb /mnt/hdb
VFS: Can't find ext2 filesystem on dev ide0(3,64).
mount: wrong fs type, bad option, bad superblock on /dev/hdb,
or too many mounted file systems
That's as far as I got. Anyone? HELP!
(Note: The slave drive has already been formatted as a Rio Central drive already, using the "Restore to as new" CD for version 1.10.)
