Well, it turned out to be pretty simple. I opened the player up and lifted out the drive tray. I then saw that the cable was half off the main board. I pushed that into place, plugged in the player and it started up right where my playlist left off.
However, this opportunity seemed like a good one to have a go at upgrading my capacity. So I followed the instructions in the FAQ, which were a bit scary for someone who's never seen the inside of his own empeg, but I soldiered through.
Once finished, I booted up with hyperterminal running and it indicated it could see the two drives. I then launched emplode to check my new capacity, and was disappointed to see it still at 11GB.
I'm pretty sure I know the problem, though, so I'm not too worried. The drive I bought was a Western Digital (it was the only brand I recognized in the store), but the only problem is it didn't come with a jumper. I gave it a go to see if it would work without one. I guess it didn't. Does it sound like if I just get a jumper, the problem will be fixed? And if so, my next problem is that I can't find any documentation telling me what the jumper settings are (and no, it's not written on the drive). Anyway, here's what hyperterminal has to say:
Probing primary interface...ress.cpp189 (14
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, ATA DISK drive: Spinning up.est complete:
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:9
8
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4054d000
