Personally I'd set the new WD to be the primary (since it's the newer and hopefully more reliable) and the old IBM as a slave after building both drives with the builder image.
Why would you lose anything?
Doesn't applying the builder image completely wipe the hard disks?
Thanks, Mark. I suspected I'd need a jumper. The PDF I found proves that the WD with no jumper is the default for master or single. Now I just have to find a store around here that sells 2mm jumpers (I want this fixed ASAP ). I'm pretty sure I saw that Microcenter had them, but I'm not certain...
