Currently, there is no way to do a thing like that, other than hackin up the source and recompile. As for frontpage, that would certainly be a problem, as frontpage requires serverextentions on the websserver. It can also use FTP as protocol, but that would require you to install some kind of FTP-server on the empeg ( which is doable though ).
I'm planning some of the functionality you guys suggested in the 2.0 release, but haven't had the time to setup a complete list of specs...
Things that are on the wish/changes-list :
- uploading/downloading of user-files (filetaxi) : doable and first tests are very promising
- empegApplet with remote : done, still some bugs
- customizable HTML-files (loren's suggestion) : doable, but requires some stable parser mechanism
- usable backup-functionality : in progress
- new framework design : still experimenting with different message-passing schemes
- logging of requests
- server-side daemon for "IP over USB"
Above list is from memory (I'm at work now), so I probably forgot some...
Frank van Gestel
Frank van Gestel
