Have you seen any errors on the serial port through hyperterminal? You may need to bounce the eth0 interface. I had trouble where it would give strange behavior (along with the "neighbor table overflow" error), but I have been using ifconfig to set the ethernet port down and up, then running displayserver, and it seemed to fix the situation. I don't know if it could be a related problem, but it might be worth a try...
Paul G.
SN# 090000587 (40GB Green)
Paul Grzelak
