Paul,
Did it fix the problem for good, or do you have to do this every time you use displayserver? I didn't see any errors when updating to 1.02/picker/displayserver. Other than those sorts of things, I don't use Hyperterminal much. I'm fairly new to Linux and did use ifconfig to set up my test linux box at work, but haven't used it with empeg. I assume by bounce you mean turn off & turn back on the eth0 adapter on the empeg?
-Z
just say you weren't paying much attention...
WWFSMD?
