Sean - it happens even when everyone's gone home for the night, so I don't think saturation is the problem.
Frank - my 'ReserveCache' is set to 12 (as I found it). I had mistakenly set this to 32 with bad results. I've got 'ReduceCache' set to 16 at the moment (and ReserveCache back to 12). I've attached my config.ini file, which I've been editing with UltraEdit to avoid the end of line problems pointed out. Three songs seems to be about the limit.
The config.ini file I'm editing resides in the /empeg/var directory which I believe is the right place. I use Hyperterm and do the following: cd to the /empeg/var, rw, rwm, cp config.ini config.old, rz the edited config.ini file, ro, rom, exit, reboot power. Please let me know if this is not right. I'm using Displayserver 1.1 dated Feb.16.
I'll try it with the player quit and see how that goes.
-Zeke
just say you weren't paying much attention...
28177-config.ini (198 downloads)
WWFSMD?
