I have been trying and trying to get an old mk2 player to boot up, and keep getting the infamous 'No hard disk found...' error. I have checked the faq and threads, and have checked the header cable and other items that I have found, with no luck so far.
So I figured to start from square one (again), and 'hypertermed' into the unit (with the serial cable) and here is what came up
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v464 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Oct 27 01:00:29 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101787) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80) --> no visuals for Tuner/AUX.
empeg state support initialised 0089/88c1 (save to d0004f00).
empeg RDS driver initialised
empeg single ch
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xffdf
ide_data_test: wrote 0xffff read 0xffdf
ide_data_test: wrote 0xaaaa read 0xffdf
ide_data_test: wrote 0x5555 read 0x7f55
ide_data_test: wrote 0xaaaa read 0xff8a
ide_data_test: wrote 0x5555 read 0x7d55
ide_data_test: wrote 0x5555 read 0xffdf
ide_data_test: wrote 0xaaaa read 0xfb8a
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
I am hoping that someone with more smarts than I (after all, I AM a conservative!) can take a look at the above, and tell me if it looks normal or does something obvious jump out. I am really about at my 'wit's end' ... Any help would be greatly appreciated!!!!!
Thanks
Ladmo
