Okay. I tried all the suggestions, but no luck. Below is bootlog after the CS4231 fix.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30103020) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
CS4231A: not responding (00) --> no visuals for Tuner/AUX
empeg state support initialised 0089/88c1 (save to d0004900).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xfe83
ide_data_test: wrote 0xffff read 0xff83
ide_data_test: wrote 0xaaaa read 0xea82
ide_data_test: wrote 0x5555 read 0x5581
ide_data_test: wrote 0x5555 read 0xd583
ide_data_test: wrote 0x0000 read 0xfe03
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xeaab
ide_data_test: wrote 0x5555 read 0x5555
ide_data_test: wrote 0x5555 read 0xd555
ide_data_test: wrote 0x0000 read 0xff03
ide_data_test: wrote 0xaaaa read 0xeaaa
ide_data_test: wrote 0x5555 read 0xff57
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:cc
RAMDISK: Loading 320 blocks [1 disk] into ram disk... | / - \ | / - \ | / - \ | / - \ | / - \ done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
