Yes, Mark, there was a drive installed. I'm not entirely sure it is good at this point....
The drive is probably fine -- you could try it in another machine if you're worried about it, but I suspect there's nothing wrong with it. The real problem here is the (very likely) fried ethernet chip, which shares the bus with the drives, USB, and other stuff.
