#297820 - 03/05/2007 13:43
Re: VPN Help Anyone?
[Re: wfaulk]
Quote: I have my home network bridged so other PC's at home can connect to the web.
The way you put it, it sounds like you're using the Windows Connection Sharing thing. If so, which computer are you trying to connect from? The one that's connected directly to the modem or one that's connected to the sharing computer?
I'm using the one that is connected directly to the modem via ethernet. I didn't try the other ones because I thought the bridged network would even be less likely to work. I'm thinking since I'm using ethernet to connect directly to the modem that may be causing the issue.
Even though it's directly connected it's still an internal network. Maybe I'm wrong. I've got no idea and have been at this for days.
