#297842 - 03/05/2007 18:45
Re: VPN Help Anyone?
[Re: wfaulk]
Quote: Your main computer is functioning as a router. That's what "Internet Connection Sharing" does.
Can you run through their steps and find if you fall under "Static IP and DHCP disabled" or "Static IP and DHCP enabled", please?
Thanks, I am using DHCP with 192.168.0.1 as the gateway. I can’t see anywhere where it says if I have a static IP. It mentions that the static IP should be the same inside the network as out. On the web I look like I have an IP that starts with 66. In the setup for the modem it says LAN 1 IP is 67.45.30.125.
Maybe I should setup DHCP to look at the 67.45.30.125 number or the 66 number. I’m starting to get dizzy with all this info.
LAN1 IP Address: 67.45.30.125 LAN1 Subnet Mask: 255.255.255.252 NPR IP Address: 192.168.0.1 NPR Subnet Mask: 255.255.255.0
