There is a mode on the Sync system called "autoplay" that starts streaming bluetooth audio as soon as the system connects to the device (if the stereo was left on). It runs the iPod app and plays the currently playing track. I can switch to Pandora or whatever and it will still stream the audio over bluetooth, but I need to manually switch from the iPod app to the Pandora app. I haven't tried it with Public Radio Tuner yet, or the Minnesota Public Radio app. By the way, there is a fantastic public radio station in Minneapolis called The Current, which you can stream for free from the web or the Minnesota Public Radio app. Worth checking out...
Yep, that works beautifully with my new Prius too (A2DP streaming & AVRCP). If I'm in the car, whatever I last had running as an audio app - ie the icon shown when you swipe left-to-right on the multitasking bar - gets streamed to the car and the usual things like track skip work.
I've used this with Pandora and Slacker radio just fine. If only AVRCP would have defined a standard way to send metadata then it'd be probably all most people would need....
