Funny you should mention DivX, I first would have said 'No way, can't be done' but then I found this : [url:DivX for PocketPC]http://www.projectmayo.com:80/projects/subproject.php?projectID=6&subprojectID=11[/url]
Mind you this is based on WinCE 3.0 or Pocket OS or whatever you want it to be called. Still I would suspect supporting fair to high quality stuff is beyond the strongarm. But it has surprised is all in the past, might do so again. But if you look at the resolutions this coded is suggested to be used you will see what I mean.
Hans
Mk2 - Blue & Red - 080000431
Mk2
This message will selfdestruct in 5 seconds to prevent reproduction.
