Whatever happens, please don't split "off topic" (or whatever it's called tomorrow) into sub-forums. It may have been years since I had a running empeg, but I still value this community and want to keep it around, and off-topic is the perfect place where I can complain about my borked router or whatever else and get the sort of signal-to-noise ratio that only happens here.
Ditto.
Also, I personally think it is generally bad to split when you have a shrinking user base. If you want to favor trafic on the boards, then a split would make it harder form many to know that a topic exist, unless they browse all sections. These days, when I come to the empeg bbs I only look at off topic. I find out about topics elsewhere once a week, or once a month, when I go there. If others have my same usage pattern, a split would reduce overal boards interaction.
