Ok, I need more help. Address Book (in Lion with iCloud) is driving me UP THE WALL.
In its preferences I can clearly see that I have both iCloud and "On My Mac" local accounts. However, if I try adding a group, it ALWAYS goes into iCloud. I'd like to set up an address group that's local only so that it will not be synced to other devices and I simply can't figure out how to do it.
The other PITA is that let's say I want to get rid of a group and all its associated addresses... There's no way to do this. If you delete the group it doesn't actually delete any contacts. So now you'll be left with potential duplicates or at the very least extra contacts that you may not want. All listed in the "All Contacts" view. Good luck trying to figure out which ones were the ones belonging to that group.
The workaround I found was to export every group you want to keep to a vcard, then delete ALL addresses and all groups, re-create the groups you want and then import the vcards you previously exported.
An unrelated issue I'm having is when bringing up search results in Google from the Apple discussions forum (some links only), clicking through won't let me see the discussions. I'm prompted to re-verify my AppleID password and then it always fails due to an "unknown error" - arrgh! Already tried deleting cookies. And the login works fine for the developer pages and iTunes.
Edited by hybrid8 (17/03/2012 13:51)
