You're right. They were back to front. But then it still did't work.
Then I tried setting it to port 80 in the setup menu of the Loxone server, and then it worked. But I don't want to use that port for security reasons. So I then reset the port back to 7777 and guess what? It kept working!!
Very strange, but I guess I'll just be happy it works and not worry about it.
Thanks for the help!
The first time you tried it you did give the controller enough time to provision the USG? Changes in the unifi world are not realtime, you have to wait until the controller decides to provision the changes on the device you've modified and then wait enough time for that device to update and reload it's new configuration. Normally this doesn't take very long, but as I said, it's not a realtime change.
