Do you run drive image every night? Does it copy everything or just the things that changed since the last time it was run?
I only run it when the thought hits me that I haven't done backup in a long time. I don't have any mission critical data on my home computer, so every couple of weeks is often enough.
I have it set up to just recreate the entire C: drive partition on my D: drive, rather than try and get fancy and use it as a backup utility with incremental capabilities. I think (not sure) it can be configured to do so if you want, however. It takes surprisingly longer than I thought it would to mirror the partition -- something in excess of two and a half hours, mirroring a 40GB C: drive to an identical 40GB D: drive, but I just let it run unattended overnight so no big deal.
