Make sure the Com port is set right in the logo program, and that you have any other devices using a com port turned off (like a modem, or Palm Sync software). Have you been able to do an upgrade on the unit? Also, try connecting with Hyperterminal to see if you can watch the bootup messages on the empeg. This should help to determain if it's a com port problem.
