Just checked the Hard Disk Detection menu in Hijack and it is set to two drives...
The adapter has a master/slave jumper which is set to slave...
In the meantime I discovered something else:
If I try to run the CF card as master and the HDD as slave they both get detected allright. My problem is, that I need to do it the other way around, as I do not have the Empeg kernel on the CF cards....
