Hi!
The spec sheet look promising!
I tried to setup my win2k with original server but I can't get past the "waiting before retry" message.
Here's are a few observations:
- In installation manual you ask to replace in trio.xml f:\dist\ by installation directory...There's no f:\dist\ but there's f:\code\ so I replace all of them with my installation directory. Is it ok?
-Still in trio.xml, should I change the broadcast address to my local network? ie my ip are 192.168.0.11 for the server and 192.168.0.23 for the receiver, should i change broadcast to 192.168.0.255 instead of 1.255???
- In trio.bat, there are two possible lines to launch trio host.. the first one is not supposed to create a window on the host PC BUT when I use it, it creates a window which stops at "creating UDP socket. local port 19680, timeout: 15000"
Is it normal?
Included is a copy of my trio.bat and trio.xml, if ever you need them to help me
EDIT: Is there any way to attach? if not, I can email if needed
Thanks!
Patrick Giasson
Patrick
