So, to recap, switching to that mpg123 plugin is the solution to the timing problems?
Yes.
If so, any way the plugin could detect which one is selected and complain/warn if it's not the one we want?
I suggested this very thing to Patrick in Instant Messenger mere moments after confirming that the mpg123 pluging solved my problems.
Am I the only one who can no longer edit ID3 tags in WinAmp with that plugin?
I never tried, but the readme for mpg123 says:
"*** ID3 tag editor is not fully tested. Backup your file before using this function. ***"
So I suppose that would be expected behavior.
Well, it's easy enough to switch back to the regular plugin (just put "MP3" back into the configuration screen for in_mp3.dll).
